Hi Genero, Make sure you are not defining the Slave axis when defining the Coordinated Motion Axes with DefineCoordSystem() Regards TK
Message: 8087 |
Date: 8/11/2013 |
Subject: Re: Slave Axis is not moving on G-code program |
Thanks for the hint, that was the problem, I fixed it and now everything is working fine.
Saludos desde Tijuana Mexico,
Genaro.
> Hi Genero,
> From: eypisa <energiainteligente.sa@...>
> Sent: Wednesday, August 7, 2013 11:26 PM
> Subject: [DynoMotion] Slave Axis is not moving on G-code program
> Hi Tom,
> I building a CNC plasma using KFlop+KStep and Mach3 software. I already setup on KMotion the channel 3 as slave of the Channel 1 (Y axis ) and it works OK on the "Step / Response" function, then I copy-paste the Channel 3 C program on the "InitKStep4Axis" file.
> I tested new configuration on Mach3 jogging function and it works fine, both steppers moves OK, but when I tried a G-code program the slave stepper (channel 3 output gain -1)is not moving, then I tried differeny programs getting same results.
> My problem is that slave stepper is moving just in jogging function but not during the G-Code program, Can you tell me how to fix this problem?
> Thank you,
> Genaro Robles.
